Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Murano
Electrical
Alternator
Alternator pigtail?
2005 NISSAN MURANO
169,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JEWELSLYNNE79
MEMBER
I would like to know the order of the pigtail and the wires that go to the alternator because I had had pulled the wires out of the pigtail.
Mar 26, 2023 at 1:27 PM
BORIS K
Experienced Mechanic
Hello.
A good video:
https://youtu.be/DtFQKXn5yro
Image below for pigtail harness on alternator
4 - Grey --> Black (common)
3 - Yellow/Black --> Green (sense)
2 - Brown --> Red (lamp)
Image 2 is the original wiring connector to alternator
Black/Yellow - Battery
Brown - Charge to Gauge cluster
Grey - IPDM
Hope this helps.
Cheers, Boris
Images (Click to enlarge)
Mar 26, 2023 at 8:28 PM
JEWELSLYNNE79
MEMBER
Okay, so what if we got a 250 amp alternator it has a 4 prong plug?
Mar 27, 2023 at 2:57 AM
JEWELSLYNNE79
MEMBER
And also, it's a two prong plug for the original alternator, and we have a 4-prong plug.
Mar 27, 2023 at 5:25 AM
BORIS K
All the technical wiring diagrams are listing 2 or 3 pin alternator connectors.
See images below.
The 3 wire alternator is for smart charging controlled by the IPDM on the light blue wire
Did the supplier of the 4 wire alternator not supply a connection guide to either 2 or 3 pin connector?
Cheers, Boris
Mar 29, 2023 at 10:42 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
