Alternator or cam sensors?
123,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
DR. AUTO ADLER
  • 6 POSTS
Hello, Ken.
I have that 2012 f150 that you helped me with that I put the 2017 5.0l in and put the 2012 camshafts in it. You helped me get the timing correctly.
Now il getting a P0625 and ( that's the code that will not clear), then when running it comes up with misfires and P0340 and P03440. Battery seems fine. Where is F circuit on the alternator and does the alternator really affect the cam sensors and timing that drastically to misfire 2,3,4,7,8. Thanks again..
Aug 21, 2025 at 7:39 AM
  • 55,721 POSTS
It looks like the alternator might not be charging, I would start the engine and use a voltmeter to check the output. This guide can help:
P0625 - Generator Field-F Terminal Circuit Low
P0340 - Camshaft Position Sensor Circuit (Bank 1, Sensor A)
P0344 - Camshaft Position Sensor Circuit Intermittent (Bank 1, Sensor A)
The bad news in this camshaft codes come up if the timing chains are off a tooth. It is difficult to get the mark correct on these engines. :/
Aug 22, 2025 at 1:51 AM
