Alternator not charging battery?
169,567 MILES • 3.7L • V6 • 2WD • AUTOMATIC
CLAYTONMAYO
  • 5 POSTS
So, I have the vehicle listed above Coupe and I’m having an issue where when driving my battery is not getting charged by my alternator even though my alternator is not faulty and getting power at all connections, it’s like my alternator is getting power but not putting any out.
Mar 24, 2023 at 12:53 PM
  • 110,251 POSTS
How was the alternator tested? Did you remove it and have it bench tested?
I attached the wiring schematic below of the charging system. I highlighted fusible links and a fuse. Have they all been checked?
See pic below.
Mar 24, 2023 at 4:41 PM
CLAYTONMAYO
  • 5 POSTS
The alternator was removed, and bench tested, I have tried two different alternators brand new (non-refurbished) and a used OEM one. I will get back with you on the fuse links.
Mar 24, 2023 at 5:07 PM
  • 110,251 POSTS
Sounds like a plan. I wanted to make sure it was bench tested. If it is good, then the issue is in the vehicle. I suspect we have a faulty fusible link.
Mar 24, 2023 at 5:25 PM
CLAYTONMAYO
  • 5 POSTS
I took a look at the fusible links it does not seem like they are broken in any way at all.
Mar 26, 2023 at 3:02 AM
  • 110,251 POSTS
Sounds good. If possible, let me know what you find. I'm interested in knowing.
Mar 26, 2023 at 12:50 PM
CLAYTONMAYO
  • 5 POSTS
Hey Joe, I’ve replaced the fusible links but that did not help, the alternator connector is getting power on all 3 wires, the ground is good, I'm just stumped at what this could be. Any suggestions?
Mar 28, 2023 at 1:53 AM
  • 110,251 POSTS
Okay. We need to test one thing at a time. Start with the B terminal on the alternator. See pic 1 below.
The remaining pics are the diagnostic procedure to test the B terminal. The B terminal is the circuit that sends power to the battery.
Let me know what you find.
Mar 28, 2023 at 1:33 PM
