Replaced the alternator and battery. Car is still not charging.
Jun 2, 2025 at 9:14 AM
✓Experienced Mechanic
Okay, the first thing to do is check the fuses using this guide which shows you if you have power as well. Please check fuses: # 16 and 17 in fuse panel B and check the #1 in the fuse panel A.
