Alternator Not Charging the Battery
2008 PONTIAC GRAND PRIX
240,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
DEDRICK CONWELL COLLINS IV
My car wont start unless i give it a boost, I have changed the alternator and the battery. Once it starts by jumping it and i remove the cables, on the dash it says "charging system failure". Can someone please help me with this issue? Some people say its the starter or the voltage regulator. But i am not sure. i need to know exactly so i can get his taking care off ASAP! i am desperate for help!
Jun 20, 2016 at 9:35 PM
JDL
  • 16,098 POSTS
Check for applicable trouble codes. To check codes, yourself, at the least you need an obd2 code reader will check manufacturer specific codes as well as po codes, see if anything for charging system. You have regulated voltage control, there are several modes with this system, the voltage output depends on the mode.
You could use a digital multi-meter at generator bat terminal, engine running, with a load turned on, what is the reading?
You can also, check battery amp draw, with everything off. That spec is usually very low, if too high, you have a battery drain. If the battery is down, you need to use a charger to charge it up. It is hard to do any testing with low battery.
If you put the meter leads across battery posts, everything off, the generic spec for a full charge is around 12.6 volts.
Jun 21, 2016 at 3:01 AM
RENEE L
  • 1,260 POSTS
Hi Dedrick,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jun 22, 2016 at 3:49 AM
