Where is the Alternator located?
217,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JUDIE_SIMMONS
  • 57 POSTS
I am trying to replace my alternator on my vehicle listed above GLS and I am having trouble locating it.
Feb 1, 2022 at 2:47 AM
SQM
  • 6,383 POSTS
The alternator is located toward the bottom of the engine. It is right next to the crankshaft pulley.
In order to replace the alternator, you will have to access it from under the vehicle. Which means removing the skid plate. Also, the A/C compressor will need to be removed to get the alternator out.
https://www.2carpros.com/articles/how-to-replace-an-alternator
I have attached a diagram for your reference.
Feb 1, 2022 at 3:02 AM
JUDIE_SIMMONS
  • 57 POSTS
My car has been sitting for a while and I just was able to get the battery charged at AutoZone if it doesn't start up this time how will I know if it's the alternator or starter?
Feb 1, 2022 at 3:40 AM
SQM
  • 6,383 POSTS
Keep in mind if it is the alternator then it will start but will not stay running. Usually, the engine will stall as soon as the battery gets discharged by the alternator.
You can also do the alternator test.
And of course, if the starter is bad then you might just get some clicks.
Let me know how it goes.
Feb 1, 2022 at 4:34 AM
JUDIE_SIMMONS
  • 57 POSTS
Okay, so, I am still troubleshooting so far, I have a new battery and gas in the car and it's still not trying to start, but it's making the attempt to start by going through the motions.
Feb 1, 2022 at 10:49 PM
SQM
  • 6,383 POSTS
So, the engine is cranking over but not starting?
Generally speaking, an engine will need spark, fuel and compression to start.
So, if it is cranking over, it tells you that the starter is good.
Now you will have to check and see if you have spark to the plugs.
Also, can you hear the fuel pump come on, when the key is turned to the on position?
Take a look at this guide, it covers the typical issues when the engine cranks but does not start:
https://www.2carpros.com/articles/car-not-running-advanced
Feb 1, 2022 at 11:02 PM
JUDIE_SIMMONS
  • 57 POSTS
What is the sound or noise need to listen for to tell if my fuel pump turns on? because there is 1 gallon of gas in there and it's not registering that there is any gas in there when I turn the key to start the car.
Feb 2, 2022 at 12:00 AM
SQM
  • 6,383 POSTS
It is a distinctive buzzing or humming noise. If you are in a quite area, it is reasonably easy to hear. It will turn on when the key goes to the on position (not start) for few seconds and then shut off.
Feb 2, 2022 at 12:58 AM
JUDIE_SIMMONS
  • 57 POSTS
Here is a little video of the car trying to start:
Feb 2, 2022 at 1:02 AM
SQM
  • 6,383 POSTS
Hard to tell from the video if the fuel pump is turning on.
But does the engine actually cranks over? It was difficult to tell from the video. I can see the lights flicker on the dash, but the noise did not sound like it was cranking.
Feb 2, 2022 at 1:28 AM
JUDIE_SIMMONS
  • 57 POSTS
I don't know if you could hear the sounds of the video in the last one, so I had to do it again, is it the alternator.
Feb 2, 2022 at 1:51 AM
SQM
  • 6,383 POSTS
It's almost like there is not enough power.
Did you try to jump start it?
When it is the alternator the engine will stall when the jumper cable gets removed.
Feb 2, 2022 at 3:11 AM
JUDIE_SIMMONS
  • 57 POSTS
No, I have not tried that since I put the new battery in. I will try that tomorrow and let you.
Feb 2, 2022 at 10:20 AM
SQM
  • 6,383 POSTS
That sounds good.
Feb 2, 2022 at 10:50 AM
JUDIE_SIMMONS
  • 57 POSTS
What is a good price range for a used, remanufactured and new alternator?
Feb 2, 2022 at 11:54 AM
SQM
  • 6,383 POSTS
Typical remanufactured alternator runs around $130.00 to $140.00, new ones can run about $250.00. That is the price you will see from parts stores like AutoZone or O'reillys.
Feb 2, 2022 at 1:59 PM
JUDIE_SIMMONS
  • 57 POSTS
I am going to go back to the troubleshooting process, so I am going to try using a jumper box it has 600amp the portable ones.
Feb 3, 2022 at 6:07 AM
SQM
  • 6,383 POSTS
600-amp jump box should be strong enough, as long it is fully charged.
You will at least get a few cranks out of it even if for some reason it does not start.
If it cranks over strong but does not start, then it could be an issue other than an alternator. If it starts but stalls after you remove the jump box, then it is probably the alternator.
Feb 3, 2022 at 6:13 AM
JUDIE_SIMMONS
  • 57 POSTS
Okay, thanks, I will let you.
Feb 3, 2022 at 6:18 AM
SQM
  • 6,383 POSTS
Sounds good.
Feb 3, 2022 at 6:19 AM
JUDIE_SIMMONS
  • 57 POSTS
I'm not too sure if the jump starter is working correctly so I'm not sure that I can rule out the alternator from this video what is it sounding like to you.
Feb 3, 2022 at 7:45 AM
JUDIE_SIMMONS
  • 57 POSTS
Where is the starter located is it in the same area as the alternator or close by?
Feb 3, 2022 at 7:48 AM
SQM
  • 6,383 POSTS
Yes, it is located at the bottom of the engine towards the back.
Feb 3, 2022 at 10:37 AM
JUDIE_SIMMONS
  • 57 POSTS
Can I have a diagram of the starter position and location?
Feb 3, 2022 at 8:33 PM
SQM
  • 6,383 POSTS
Since this is a different part, kindly open a new thread.
Simply go to this link and put your question:
I will lookout for it and will provide you with the answer.
Feb 3, 2022 at 10:06 PM
JUDIE_SIMMONS
  • 57 POSTS
I asked a new question already.
Feb 3, 2022 at 10:45 PM
