Alternator issue
211,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GREGORY MICHAEL YATES
  • 89 POSTS
Hi Folks,
I have a battery light on dash and my battery is not charging.
I replaced alternator and started engine and no battery light.
Then I drove a few miles and light is back on and battery is not charged
I went cheap on buying a cheap partially rebuild alternator.
Or maybe the problem is not alternator but wiring or connector, etc?
Jun 11, 2019 at 5:17 AM
Hi Gregory,
We need to perform an alternator test. If the alternator is charging but the battery is drained then it can cause that light to come on as well so we need to have the battery tested as well.
Basically this light is telling you that the overall charge of the vehicle that the PCM is reading is not sufficient.
It could be the battery, alternator, wiring, or a PCM. The fact that the light goes off and then comes back on makes me think either the alternator is bad or the battery is weak.
Keep me posted on what you find. Thanks
Jun 11, 2019 at 9:37 AM
  • 89 POSTS
Okay, thanks. I will have battery checked first.
Jun 11, 2019 at 10:10 AM
  • 89 POSTS
Sorry for delay. Was a bad battery.
I sold the car. Good riddance to Glemlins.
Thanks again.
Jun 25, 2020 at 7:42 AM
Failed batteries are the worst. They cause all sorts of crazy issues. Glad you got it resolved and unloaded the car. Hopefully it will be just fine for someone else. Thanks for using 2CarPros.
Jun 26, 2020 at 12:44 PM
