After driving a short distance warnings lights turn on and engine shuts off
200,000 MILES • 3.3L • 5 CYL • 2WD • AUTOMATIC
KAY SIENNA 03
alternator is good, battery is brand new but after running a short distance the ABS light, airbag light and caution light come up and the engine goes off and drain the battery dead. thanks for any help.
Feb 9, 2020 at 6:29 AM
  • 110,248 POSTS
With the vehicle running, I can think of anything that will totally kill the battery that quickly. I have a feeling it is either connection issue or either the battery or alternator is at fault. When this happens, do you have to have the vehicle jump started or does it require the battery be recharged?
I'm not sure what was done to check the alt and battery. However, if something is killing the battery as fast as you say and the battery is new, I'm concerned there is a major electrical issue that could lead to a fire. Do me a favor. I need you to check the basics. First, make sure the battery terminals are clean and tight. Second, follow this link for testing an alternator and let me know what you find.
Here are a few links you may find helpful:
Let me know what you find.
Feb 9, 2020 at 1:28 PM
