Can I get the Pinout diagrams for 2005 and 2008 alternator Electrical connectors and the alternator wiring diagrams for both years as well?
120,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
ALEX GATLIN
  • 47 POSTS
Hi guys. So, I bought this vehicle listed above and the alternator went out. I accidentally ordered an alternator for a 2008 Equinox. I was wondering if I could get the Pinout diagrams for 2005 and 2008 alternator Electrical connectors and the alternator wiring diagrams for both years as well, in case I have to swap electrical connectors. I know it is just two wires, but I don't want to pop fuses if I guess wrong. Thank you.
Jan 23, 2025 at 11:59 PM
  • 55,743 POSTS
Hi Alex,
It looks like there are different plugs, you should be able to get a new plug and wire it in or get the correct alternator. Here are the alternator charge plug pinouts. Check out the images (below). Please let us know what happens.
Jan 24, 2025 at 2:59 AM
ALEX GATLIN
  • 47 POSTS
Okay, so would I put the one wire from the A,B,C,B connector Pinout into pin A or pin B in the other connector? The A,B,C,D single wire connector is on the vehicle and would be putting the wire into A/B connector which would plug into the alternator? Which pin is the generator turn on pin for 2008 alternator?
Jan 24, 2025 at 5:04 AM
  • 55,743 POSTS
Here are the alternator wiring diagrams so you can see how the wires go. Check out the images (below). Please let us know what happens.
Jan 25, 2025 at 8:21 AM
