Alternator belt?
2.0L • MANUAL
MUGGED OFF
Hi, we had to take our car to a garage 4 month ago and apparently the alternator belt had come off we paid 260 pound... fast forward last week and the car started to screech and then had a warning light for the battery saing the charging system had failed..
Jul 31, 2026 at 6:31 AM
  • 55,694 POSTS
Yep, is sounds like the belt has failed again but you need to check the belt tensioner and while the belt is off rotate the accessories by hand to make sure that are not locking up or have a bearing that is going out. This can be what is causing the problem with the belt. Can you upload an image of the problem from under the hood so I can see it?
Jul 31, 2026 at 9:06 AM
KRAKENAUTO
  • 113 POSTS
Your belt likely failed again. When they replaced the belt did they also change the belt tensioner? It is possible that is also bad or went bad after the fact. If you can upload a photo of the problem area it can better assist us.
Aug 1, 2026 at 1:32 PM
