Alternator
184,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KINSEYJAMES
  • 25 POSTS
My brand new alternator went out a month ago. It was replaced and now I am experiencing the same symptoms from before lights shutting off while I am driving. Could it be a computer component and is it replaceable?
Aug 21, 2016 at 3:46 AM
HMAC300
  • 48,601 POSTS
it can be a relay or fuse in under hood fuse box or a bad ground on right hand rear of cylinder head or a body module problem which will require scanning by a mechanic to see if it is.
Aug 21, 2016 at 5:44 AM
HMAC300
  • 48,601 POSTS
I assume the alternator is good if not check fusible links going to it from battery.
Aug 21, 2016 at 5:54 AM
KINSEYJAMES
  • 25 POSTS
Will a diagnostic computer find the problem? My dad is my mechanic he has one of those? Will I need to put it in a shop?
Aug 21, 2016 at 7:15 AM
HMAC300
  • 48,601 POSTS
if he has a professional model he can find the body module, if not it wont pick it up and one from an auto parts wont work.
Aug 21, 2016 at 8:18 AM
