Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Interior
Clock
Fuse
When I start the truck I lose all presets on the radio and the clock resets to 12:00 am
1999 FORD RANGER
280,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
KEND.KD75
MEMBER
would too small of a fuse make any difference?
Nov 3, 2019 at 2:30 PM
BMDOUBLE
Experienced Mechanic
Only if the fuse is blowing, then you would need to find out what is blowing the fuse. The voltage is dropping too low due to either a weak battery or bad connection at the battery through the terminals. Have you had the battery tested?
Nov 4, 2019 at 2:06 AM
KEND.KD75
MEMBER
No. But I will today.
Nov 4, 2019 at 2:11 AM
BMDOUBLE
Good deal! let us know what the results are.
Nov 4, 2019 at 3:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
