When I start the truck I lose all presets on the radio and the clock resets to 12:00 am
1999 FORD RANGER
280,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
KEND.KD75
  • 21 POSTS
would too small of a fuse make any difference?
Nov 3, 2019 at 2:30 PM
BMDOUBLE
  • 1,139 POSTS
Only if the fuse is blowing, then you would need to find out what is blowing the fuse. The voltage is dropping too low due to either a weak battery or bad connection at the battery through the terminals. Have you had the battery tested?
Nov 4, 2019 at 2:06 AM
KEND.KD75
  • 21 POSTS
No. But I will today.
Nov 4, 2019 at 2:11 AM
BMDOUBLE
  • 1,139 POSTS
Good deal! let us know what the results are.
Nov 4, 2019 at 3:59 AM
