Alternator is not charging the battery?
153,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
TOM5406!1242
It is not charging the battery and if I keep the vehicle running too long it tries to burn up the alternator. I’ve replaced the battery, battery terminals alternator and the 120 fuse in the fuse box I’m stuck.
Nov 10, 2024 at 9:22 AM
  • 55,797 POSTS
I would check the main system ground from the engine to the battery and from the battery to the chassis. Also, when the alternator is charging what is the voltage?
This guide can help:
Here are the charging system wiring diagrams so you can see how the system works and the grounds to check.
This guide can help you check the grounds:
Nov 10, 2024 at 10:11 AM
