A hose has been leaking coolant directly over and into the alternator, concerned about long term effect?
300,000 MILES • 3.4L • 4 CYL • 2WD • MANUAL
NUBFASM
hose has been leaking coolant directly over and into alternator. The alternator still works, but I'm concerned about long term effect of ethylene glycol coating the inside works. Would you recommend I try to clean the alternator? I've thought of pouring lots of hot soapy water through it to rinse out the ethylene glycol, but I'm afraid that might be a really bad idea. What's your advice? Thanks!
Dec 27, 2023 at 3:25 AM
  • 55,782 POSTS
Yep, you have the right idea, just wash it out with soapy water and you should be okay, no long-term effect.
Dec 27, 2023 at 9:32 AM
NUBFASM
thanks!
Dec 28, 2023 at 3:44 AM
  • 55,782 POSTS
You are welcome, please use 2CarPros anytime we are here to help.
Dec 29, 2023 at 2:22 AM
