Alternator
274,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
CARLINIETO47
How do you know if your alternator is going out if it's still charging your battery?
Feb 18, 2016 at 9:02 AM
CATAFINA
  • 167 POSTS
Read the battery voltage before you start the car then read it again while engine is running it should read within 2 volts if not there's a problem.
For example its 12.5 before you start the car and it reads 14.5 while running-the alternator is doing its job
Feb 18, 2016 at 10:25 AM
CJ MEDEVAC
  • 11,000 POSTS
CATAFINA IS SPEAKING "ELECTRICALLY"
IF IT'S SQUEALING OR MAKING A GRINDING SOUND, "MECHANICALLY", THE BEARINGS OR BUSHINGS INSIDE MAY BE WORN OUT OR FAILING.
THE MEDIC
Feb 18, 2016 at 11:18 AM
  • 55,746 POSTS
Also if a diode is going out the alternator will change the battery with AC voltage which is bad, here is more information on how to test it correctly.
let us know what you find
Mar 7, 2016 at 6:19 AM
