Alternator
2003 CHEVROLET VENTURE
270,000 MILES
ALICIAV
I have replaced my vans alternator just went again for the second time in seven months. I will be replacing it again this week and was wondering why this keeps happening and if there is anything I can do to stop it from happening? It makes me believe that there is a wiring issue but i don't know which wire would be the issue. Can you please give me some ideas?
Apr 21, 2013 at 3:27 AM
are you sure you put the correct alt on this??? it has 2 different amp readings and if you used the lowest, it will burn out.
assuming you have warranty on this as it is under a year, see if you can upgrade
Apr 21, 2013 at 3:39 AM
ALICIAV
Can you tell me the bigger size! I was just told that yes it was the smaller amp'd one and i'm going to look for the bigger one but I need to know the amp size!
Apr 21, 2013 at 4:09 AM
