Alternator replacement
100,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
CHEVYVANANT
Changing alternator, have battery completely disconnected. Tester light reveals power is coming from wires that connect to alternator. Not understanding where this power is coming from.
Apr 3, 2019 at 7:08 AM
Good afternoon,
Which wire has power? There are three wires. One from the battery, one from the cluster and one from the ignition.
There should be no voltage anywhere with both cables off the battery.
Apr 3, 2019 at 8:18 AM
CHEVYVANANT
Thanks for your response. Identified problem. It was an ironic mistake on our part. Had a couple solar chargers/jump start panels hooked up through cigarette lighter power lines and forgot about them. Duh! Anyway, they were keeping power going to the alternator lines. So, thanks again for your response.
Apr 4, 2019 at 11:28 AM
You are welcome.
Always glad to help.
Apr 4, 2019 at 11:47 AM
