Alternator can't be moved from engine?
25,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DONABUNDANCE123
Alternator can't be moved from engine I've already dissembled it and I can't get windshield motor out way
Feb 6, 2026 at 7:00 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Use the service procedure for the exact vehicle when planning removal and reassembly, including access through the wiper area. Verify damaged fasteners and reassembled components before returning the vehicle to service.
Guidance references and applicability
2CarPros: Original discussion 1712067 https://2carpros.com/questions/alternator-18108609 Source for reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. Attachments were not verified.
Read the replies · Discussion summary and reported outcome
DONABUNDANCE123
Alternator is already dessembled but I stripped nuts on wiper assembly in other alternatives on how to remove alternator?
Feb 6, 2026 at 7:02 PM
DONABUNDANCE123
It's stuck in engine compartment?
  • 55,694 POSTS
You can remove the alternator by loosening the engine mounts (torque mount) and tilting the engine forward using a floor jack and a piece of wood on the oil pan, this will give you clearance to get the alternator out. Please upload a short video in your response of the problem, so I can see what's going on. Ken
Feb 7, 2026 at 1:32 AM
DONABUNDANCE123
I removed windshield wiper assembly moved with no problem
Feb 7, 2026 at 1:34 AM
  • 55,694 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Feb 8, 2026 at 12:35 AM
Discussion summary
The owner had detached an alternator but could not get it out of the engine compartment and was struggling with the wiper assembly. The final update said the wiper assembly was removed and the alternator then moved without difficulty.
Reported outcome: The owner reported resolving the alternator-removal obstruction.
The thread does not report alternator installation or charging-system results. The alternative suggestion to tilt the engine with a jack under the oil pan was not needed in the reported outcome and is not supplied as a procedure.
Read the original discussion
