Can a flush kit tee be used as a heater control valve
213,000 MILES
DR9654
Can i use a flush kit tee as a heater control valve alternative in a my car?
Dec 13, 2016 at 1:01 PM
STEVE W.
  • 15,385 POSTS
Are you trying to block off the heater or turn it on/off. If the former then you might be able to use it to connect the two hoses and bypass the core. If you are thinking of using it like a valve. Then no, it is an open T with no valving inside.
Dec 13, 2016 at 2:02 PM
DR9654
I just need heat and a running car.
Dec 13, 2016 at 2:30 PM
STEVE W.
  • 15,385 POSTS
Okay you currently have a bad control valve and just want to remove it and let the coolant flow? If that is the case then you could use it.
I was reading the question as "I need a control valve" Sorry.
Dec 13, 2016 at 3:25 PM
