Alternator replacement 105 amp or 100 amp?
180,000 MILES • 3.1L • 6 CYL • 2WD
JEFFER10
  • 5 POSTS
This van has two alternator choices. Can I put 105 amp on to replace the100 amp without any problems?
Feb 14, 2022 at 1:35 AM
AL514
  • 5,692 POSTS
Yes, if they make a higher amperage Alternator for your vehicle. Many people do this when they have a sound system that requires extra current flow, or some other system that needs higher power/wattage. The engine computer will only command on the Alternator when it needs extra power. Most Alternators now are Pulse Width Modulated controlled to keep the battery at a certain level, this is done by the Engine Computer (ECM). 5 more Amps is really not much anyway.
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Feb 14, 2022 at 3:28 AM
JEFFER10
  • 5 POSTS
Feb 14, 2022 at 9:35 AM
