The upper control arms are bad I cannot find replacements everyone that I find the screw in ball joints the thread is worn out. so every time I put one in the ball joint pops loose. is there a alternate control arm I can use that is either pressed screwed or riveted in place to where I don't have to worry about them popping out? A mechanic suggested welding in place to help the worn out threads hold the ball joint I'm at wits end and don't want to junk my truck. The picture is of the last control arm failure the ball joint came out and did not notice until I went for alignment ruined the third ball joint and this upper control arm. please help. can I use the second gen upper control arm or if not a suitable replacement. Thank you
Dec 14, 2019 at 11:43 AM
