Alternator replacement
91,020 MILES • V6 • AUTOMATIC
MDSLOCUM00
How long should it take roughly to change the alternator? i need to replace mine?
Jun 16, 2019 at 1:13 PM
  • 110,248 POSTS
The labor rate is 1.4 hours with the correct tools. It may take longer without a rack to lift the vehicle. See pic 1 for labor time.
Here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-an-alternator
Here are directions specific to your vehicle for replacement. The remaining pics correlate with the directions.
__________________________________________
2007 Ford Five Hundred 2WD V6-3.0L VIN 1
Procedures
Vehicle Starting and Charging Charging System Alternator Service and Repair Procedures
PROCEDURES
GENERATOR
Part 1
pic 2
Part 2
pic 3
Removal and Installation
1. With the vehicle in NEUTRAL, position it on a hoist.
2. Disconnect the battery.
3. Rotate the accessory drive belt tensioner counterclockwise and position the accessory drive belt aside.
pic 4
4. Remove the 8 pin-type retainers and the right lower splash shield.
pic 5
5. Disconnect the crankshaft position sensor and release the 2 wiring harness locators from the generator splash shield.
6. Remove the lower generator boot pin-type retainer, fold the boot upward and disconnect the generator electrical connector.
7. With the generator boot folded upward, position the protective cover aside and remove the generator B+ nut and terminal.
- To install, tighten to 8 Nm (71 lb-in).
8. NOTE: The 3 generator studs and nuts may be replaced with 3 bolts (W709986-S437) to ease the installation of the generator.
Remove the 3 generator nuts and stud bolts.
- To install, tighten the generator stud bolts to 8 Nm (71 lb-in).
- To install, tighten the new generator bolts or generator nuts to 47 Nm (35 lb-ft).
9. Remove the generator shield and the generator.
10. To install, reverse the removal procedure.
When you do this, please make sure the battery is disconnected before you start. Let me know if you have other questions or need help.
Jan 22, 2021 at 6:10 AM
