Power steering and ABS not working after replacing stereo
50,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSH MCINTOSH2
I was replacing a radio and think I shorted a wire. Now the power steering, windows etc., do not work. I have checked the fuses in the engine bay. And they all seem to be fine. I cannot find any fuses above the drivers foot well though.
This is for a Toyota Allion 2008 struggling to find info on it.
Apr 24, 2020 at 12:17 PM
  • 110,251 POSTS
I have to be honest, this model isn't offered in the US, but I will try my best to help. Since you lost a few different things that don't seem directly related (ABS and Power Windows) I need you to check for grounds under the dash. Also, on similar size Toyota vehicles in the US, there should be a fuse panel under the dash on the left side. I don't know if this is left or right hand drive. But here, we have left hand drive and the fuse box is under the left side.
Let me know. Check to see if any ground wires under the dash (near the radio) were damaged or broken.
Apr 25, 2020 at 12:56 PM
JOSH MCINTOSH2
I finally found it! Thanks for the help. Was a right hand drive.
On the left hand side behind the glove-box there was a plastic shell for wires coming under and hidden on the underside of that was a fuse box with a couple of broken fuses under a cover.
Apr 26, 2020 at 10:27 AM
  • 110,251 POSTS
You are very welcome. I'm glad you found and repaired the issue. Please feel free to come back in the future is you ever need help.
Take good care of yourself,
Apr 26, 2020 at 1:09 PM
