All rear lights not working
199,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
BCRRHI1951
Headlights work. I have no lights in rear at all.
Nov 9, 2020 at 6:40 AM
  • 110,251 POSTS
If nothing in the rear works, signals, brake lights, parking lights, the one thing I see they all have in common is they use the same grounding point. What I need you to do is check the black wire on either side for continuity to ground. I attached one pic below. Each system has a different schematic (signals, brakes, tail lights) but they all show the same ground.
If you find there is no continuity to ground, as a test, run a new ground and attach it to the black wire to see if the lights start working.
Nov 9, 2020 at 12:14 PM
