all power doors and windows except drivers
2002 JEEP GRAND CHEROKEE
154,000 MILES • 6 CYL • 4WD • AUTOMATIC
NICKELUS7
i think snow got in the passenger door/window switch this week. now only the drivers door switch works, however it wont control any of the other locks or windows, including the hatch, nothing works aside from the drivers side front and rear windows and front drivers lock. i checked through other similar posts regarding the harness inside the rubber door boot, and actually had to do that repair last year which has worked great. but i believe this is related to water getting in the switch. any ideas to diagnose and fix? thanks in advance
Mar 29, 2015 at 12:23 AM
HMAC300
  • 48,601 POSTS
open drivers door and see if any other window works if they do you probably have abroken wire between door and jamb. then get it scanned for codes it may be a body module problem.
Mar 29, 2015 at 1:04 AM
NICKELUS7
thanks for your advise. after checking again on both sides there were two new wires cracking in the passenger door, after a quick repair all is better now. definitely interesting how a thick gauge wire like those could break in multiple spots. i would imagine they've redesigned in the newer models. thanks again.
Apr 13, 2015 at 12:20 AM
HMAC300
  • 48,601 POSTS
nope happens all the time, wires can only be bent so many times before they break insulation and wires...
Apr 13, 2015 at 12:26 AM
