The gauge cluster still lights up and the speedometer works. everything else is not working. Can't run the heat because you can't turn it on. Checked all the fuses and they look good. I will say that they wired in a push start button but you still have to put the key in and turn it over. Not sure if that would have caused a failure.
Jan 29, 2021 at 4:35 AM
