Self-centering of power steering
ALL OTHER MAKES ALL OTHER MODELS
TRIUMPHSTAG
Triumph Stag 1977 51000 3000cc V8
Problem: Had a reconditioned steering rack and track rod ends fittedby a specialist garage. But ... at speeds below 20mph there was no self-centering at all, so if I turned a bend, there is a horrible and scary lurch if I did not center up.
I decided to check the fluid level in the pump, and according to the level marker on the cap, there was way too much fluid put in. I removed some of the fluid, so it is spot on the level marker and went for a test drive. Well it seems alot better now, a little bit lighter and it self-centers.
Question: Would too much fluid cause the self-centering problem, or is it just a coincidence that it feels better and self-centers now some fluid from the pump has been removed?
Jun 28, 2007 at 10:33 AM
2CARPRO JACK
  • 11,533 POSTS
not sure if too much fluid will do that , might have needed time to seat the seals in the rack, or if the old rack came apart inside there could be debris in the system causing the rack to be a little sticky
Jun 29, 2007 at 8:03 AM
