1989 Acura Integra Battery Swelling
ALL OTHER MAKES ALL OTHER MODELS
BRUCE HUNT
  • 3,754 POSTS
Dcoynej
Nov 29, 2006.
I replaced the alternator on my 89 integra, but ever since then, its back feeding my batter, and swelling it up like a water melon, any ideas as to which wire I crossed?
Nov 28, 2006 at 11:36 PM
BRUCE HUNT
  • 3,754 POSTS
run a voltage test on the battery while the vehicle is running and find out the voltage that it is kicking into the battery. Could be a new alternator to you but it could be rebuilt and done poorly. Consider the voltage that you get but the issue is also whether they alternator is continously charging and thus overcharging meaning that the voltage regulator is not working properly. I really suspect the alt because the wiring is hard to mess up.
Suggested Repair
With the engine running, measure charging voltage at the battery. If voltage is high or charging never stops, suspect a faulty or poorly rebuilt alternator and voltage regulator rather than crossed wiring.
Conversation Summary
After replacing the alternator on a 1989 Integra, the owner reports the battery is being overcharged and swelling, and asks whether a wire was crossed. The expert advises checking running battery voltage and suspects continuous charging from a bad alternator or voltage regulator, noting the wiring is hard to misconnect.
