Oil in coolant
ALL OTHER MAKES ALL OTHER MODELS
TAMBO1976
I own a Holden Vectra 2001, CD sedan 2.6 V6. It has 160 000 k's on the clock.
I have oil in the coolant. The mechanic has pressured tested the heads and replaced the gasket and the problem still exists. His worst case scenario is I have a crack in the engine block.... Could there be any other reasons as to why this is happening :shock:
Oct 24, 2007 at 2:23 PM
BMRFIXIT
  • 19,053 POSTS
[quote:59dd2c9235="Tambo1976"]I own a Holden Vectra 2001, CD sedan 2.6 V6. It has 160 000 k's on the clock.
I have oil in the coolant. The mechanic has pressured tested the heads and replaced the gasket and the problem still exists. His worst case scenario is I have a crack in the engine block.... Could there be any other reasons as to why this is happening :shock:[/quote:59dd2c9235]
check the radiator
Oct 24, 2007 at 11:13 PM
