Need AC help!
ALL OTHER MAKES ALL OTHER MODELS
DQAMI
I have a 91 Acura Integra. The ac stopped putting out cold air a few months back. I recharged it w/ evironmental R12 After I recharged it, it still wasn't getting cold. I bought a pressure gauge and found the pressure was up to 70 lbs ( I know, too high). The compressor clutch is running so I'm not positive it's the compressor. Maybe a bad relay? There's so little room under the hood around there (none) I can't get to anything to test them. Any experienced help is welcome.
Jun 22, 2007 at 1:00 PM
MERLIN2021
  • 17,250 POSTS
First off the readings should be 30-40 low side, 250 high side can U test both? Do not use a single low side gauge to try this! U might have put too much freon in...
Jun 25, 2007 at 9:07 AM
