Is it possible to install a remote starter on a diesel engine? If so, how does it work with the glow plugs before starting the engine?
May 25, 2006 at 2:38 PM
A remote starter can be installed on a diesel if it is wired to the correct vehicle circuits using that vehicle's wiring diagram. Glow plugs are switched by a low-current relay and timed by the computer, so they should not prevent remote starting.
The owner asked whether a remote starter can be installed on a diesel and how it interacts with glow plugs before cranking. The expert said it is possible: the installer must identify the proper wires from the vehicle wiring diagram. Glow plugs are relay-controlled and computer-timed rather than fed by a constant hot wire, so they shut off when no longer needed and should not keep the engine from starting.
