Help Needed
ALL OTHER MAKES ALL OTHER MODELS
DOCFIXIT
  • 18,828 POSTS
Hi
Can anyone give ideas for this problem? I'm looking for reasons cannot communicate with BCM? Is this a anti-theft issue???
Thanks
Ernie
http://www.2carpros.com/forum/auto-tech-reaching-out-for-help-new-bcm-set-up-com-vt331550.html
Aug 9, 2009 at 1:03 PM
BRIAN 1
  • 1,030 POSTS
he has a class 2 communication problem,here is how to check.you have to start by disconnecting each module 1 at a time,when you disconnect the IPC,turn the key on and use the tech 2 and see if you can communicate with class 2,if you can go to the next module,ECM disconnect it see if you can communicate with class 2,if you can go to the next module,keep doing that to each module and the last one disconnected is the one that is to be replaced,also Test the DLC ground circuit terminal 5 for a high resistance or an open.also Disconnect the Fuse Block-Left I/P connectors that contain the Class 2 serial data circuits.Disconnect the connector containing the Class 2 serial data circuit from the BCM module.Inspect Fuse Block-Left I/P connectors at the terminals containing the Class 2 serial data circuits for poor connections/terminal tension.Test for an open circuit between pin 2 on the DLC connector and the harness connector of the Fuse Block-Left I/P.Test the Class 2 serial data circuit for a short to B+ or a short to ground between the mating connectors terminals integrated into the Fuse Block-Left I/P, that contain the Class 2 serial data circuits. all the modules will be listed with the tech 2,class 2 is sometimes a pain in the ass to diagnose.
Aug 9, 2009 at 1:52 PM
DOCFIXIT
  • 18,828 POSTS
Thanks Brian
That should to the job. That flux voltage on data line had me stumped but see what you mean something on the feed is causing problem.
Thanks Again let you know what happens
Ernie
Aug 9, 2009 at 3:18 PM
KHLOW2008
  • 41,814 POSTS
lol, the guy does not know what a full stop is.
Aug 10, 2009 at 7:16 AM
BRIAN 1
  • 1,030 POSTS
what do you mean?
Aug 10, 2009 at 3:30 PM
KHLOW2008
  • 41,814 POSTS
Sorry, I meant the guy who asked the question. One complete sentence without any full stops. ;)
Aug 11, 2009 at 5:23 AM
