Help!! I've put brake fluid in my coolant reservoir!
ALL OTHER MAKES ALL OTHER MODELS
WEAPON
I own A VAUXHALL CORSA 2000 1.2 SXI and i've put brake fluid in my coolant reservoir. The thing is i did this amonth ago and only realsied today.
What do i do....will this cause major problems??
Why has nothing happened already?
Any help would be very grateful!!
thanks
Jun 16, 2007 at 3:41 AM
MIKE H R
  • 3,094 POSTS
How much brake fluid did you put in the coolant? Does the car run all right? If you put a little in the coolant it ashould be ok. If you put a lot it may effect your coolamt efficiency. You say you did this a month ago. How does the car run?
Jun 16, 2007 at 5:17 AM
WEAPON
I've put in a 500ml bottle. I havn't noticed any problems at all.
Do you think i should get my radiator drained or do you think it will dilute with the antifreexe and water that's already in?
Cheers
Jun 16, 2007 at 8:40 PM
MIKE H R
  • 3,094 POSTS
if it had been over a month it probably mixed with the anti freeze. If you have any noticable changes in the cooling then i would have the system flushed.
Jun 17, 2007 at 9:15 AM
