headlight problem
ALL OTHER MAKES ALL OTHER MODELS
MP876
Supreme bus, 2000, 400,000
I have a problem with the headlights flashing, I changed the headlight switch. It worked for 20 minutes then they started flashing again. The turn signal switch was replaced about a month ago. I started tracing and checking the headlight wiring before I went home. I believe it might be a bad ground somewhere in the wiring. Does anyone know. Did I miss something. Actually I do hope that i missed something if not i'm going to upside down on my head for hours tracing wires
Jul 5, 2006 at 3:00 AM
REEZE
  • 5 POSTS
I encountered the same problem and it was fixed with the wiring. I do think that is just the same as yours. Try rechecking the wiring. Hopefully yours works just the same as mine. Good luck!
Aug 14, 2010 at 9:45 PM
