does dodge OBD1 have a way to check for open/closed loop?
ALL OTHER MAKES ALL OTHER MODELS
BUDDYCRAIGG
  • 2,262 POSTS
i can jump the pins on the ALDL of an old GM with the engine running and tell if it's in open or closed loop.
can the same be done with a dodge?
(PS i hate dodges, i dont know why i answered this guy's question in the first place)
Jun 23, 2009 at 8:32 PM
DOCFIXIT
  • 18,828 POSTS
Hey
Start if can run shifter through gears turn on AC if shut off. Cycle key on, off,on off,on MIL will flash 2 digit code.
At least it's not a FIAT
Ernie
Jun 24, 2009 at 11:37 AM
BUDDYCRAIGG
  • 2,262 POSTS
I know how to pull the codes, (although i've never had to do the gear shifter thing.)
I want to know if the old dodge system can tell you when it goes in to closed loop while the engine is running.
or more to the point, i want to verify that a car is going into closed loop.
Jun 24, 2009 at 3:15 PM
DOCFIXIT
  • 18,828 POSTS
You will need an OBDI scanner
Jun 25, 2009 at 6:45 AM
BUDDYCRAIGG
  • 2,262 POSTS
that's what i was afraid of.
Jun 25, 2009 at 7:15 AM
