Difference between Engine Light and Vehicle Light
OBXAUTOMEDIC
  • ALL OTHER MAKES ALL OTHER MODELS
Ok, this is a first for me and I am not sure what the difference is.
On a 1999 Oldsmobile Intrigue there is a Check Engine Light and a Check Vehicle Light.
The Check Vehicle Light comes on when the vehicle has an intermitant problem (hard shifting) and once vehicle is turn off and restarted the problem and light are gone, do you check codes the same way?
Thursday, September 23rd, 2010 AT 8:20 PM
SATURNTECH9
  • 30,869 POSTS
I would compare the Check Vehicle Light to the newer wrench light's Meaning that the car need's service and it is more then just a oil change etc it's something failing. From what you describe as the problem it sound's like there is a pressure problem in the transmission it's having trouble regulating the pressure so the transmission goes to max line pressure so it will shift hard in all the gear's. Then when you turn off the key it reset's the computer until the problem happens again and the hard shifting start's all over again.I have seen that same problem happen on the LS model saturn and the only code it will set is a code P1811 max trans adapative's what was happening there was the line pressure actuator in the valve body was failing. Also it was setting off the wrench light. You should be able to get the code's the normal way. Another thing I have seen cause hard shifting then turn the key off and on and it was ok again was a bad connector to the IAT sensor put's the transmission into max line pressure default mode to help protect the transmission from slipping and clutch damage.
Thursday, September 23rd, 2010 AT 11:45 PM
BMRFIXIT
  • 19,053 POSTS
When have U codes service vehicle light comes on
when have P codes service engine light comes on
when have C codes ABS light comes on
need a scan tool to check for U codes as an OBDII will not get U code s
check BCM for codes
good luck
Friday, September 24th, 2010 AT 12:36 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Thanks Gang preciate the Info.
Friday, September 24th, 2010 AT 12:45 AM
