am I an idiot or a genius?
ALL OTHER MAKES ALL OTHER MODELS
BUDDYCRAIGG
  • 2,262 POSTS
a customer has an 84 Fiero brought over on a tow truck.
The fuel pump will only run for about 1 second, even with the oil pressure switch jumped.
but if you cut the power to the pump, and then reapply it, the pump will run again for about 1 second.
I can only speculate that the armature in the pump is getting sideways a little and locking up.
and once the magnetic field is removed, then it centers up again.
so it's got 3/4 of a tank and needs a new fuel pump...
the car gods must have been smiling on me, cause in less than 30 seconds i came up with the idea of wiring in a hazard flasher into the oil pressure pigtail.
The tank was empty in about 20 minutes.
keep this in mind if you run across the same problem.
Jul 13, 2009 at 7:20 PM
  • 31,937 POSTS
Very clever... good idea...
Mark in Aus.......
Jul 13, 2009 at 8:54 PM
KHLOW2008
  • 41,812 POSTS
I am speechless. That was brilliant.
Usually failing pumps would work after knocking it a little and then it would proceed to work till you stop and the chances of having the pump acting as described is one in a million.
The bad news is your invention would have to wait for the next one in a million chance to be applicabe.
Thanks for the input, if I happen to be the next one in a million, I would definitely inform you.
Jul 14, 2009 at 7:59 AM
  • 55,684 POSTS
Now thats what im talking about, a little right brain working for you there :-)
Jul 14, 2009 at 10:40 AM
DALAMAR`
Engine Performance problem
1998 Dodge Ram
What is the firing order on a dodge ram 1500 1998
Oct 7, 2018 at 12:55 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Engine size ?????? what I have here is for v8 with 5.2
https://images.2carpros.com/forum/automotive_pictures/99387_99ram1500_1.jpg
MOPAR-ESKRIDGE
1994 Dodge Ram V8 Two Wheel Drive Automatic
firing order on a dodge 318 1994 magnum?
BLUELIGHTNIN6
  • 16,542 POSTS
Engine firing order 1-8-4-3-6-5-7-2
Distributor : clockwise rotation
Cylinders are numbered as follows:
Passenger side 2-4-6-8
Driver side 1-3-5-7
Thanks for using 2CarPros.com!
MOPAR-ESKRIDGE
the odd numbers are on the driver side and the even numbers are on passenger side. the injectors are numbered that way. you had your backwards. thanks.
