Advice
LLOYDIE
  • ALL OTHER MAKES ALL OTHER MODELS
Ive got a vauxhall zafira 2lt turbo deisel vk02 uly(02} the milage is 134000. I have replaced the airflow metre 4 times two were genuine parts im still having the same problem when I go over 60mph the engine managment light comes on it reduces my speed every time it goes on the machine it says that the problem is the airflow metre but I cant believe it is the airflow metre all the new ones cant be faulty.
Monday, April 23rd, 2007 AT 7:14 PM
2CARPRO JACK
  • 11,533 POSTS
Check real close for any vacuum leaks that may effect the readings of the MAF. If there arent any then you will need to get a wiring diagram of the vehicle and do a pin-to-pin check of all thewires for the MAF. Can you watch the oxygen sensors to be sure they are working properly?
Tuesday, April 24th, 2007 AT 7:56 AM
