99 explorer code 340
1999 ALL OTHER MAKES ALL OTHER MODELS
MASTERTECHTIM
  • 4,750 POSTS
ive got a 99 explorer with 5.0 and keeps setting cam code 340. i got this from another shop, they already replaced the cam sensor and oil pump drive. i took it apart and set it with the cam alignment tool, checked wires to the computer and they ohm out perfect, has anyone seen a worn timing chain cause this, or any ideas would be appreciated. thanks tim
Feb 2, 2008 at 4:41 PM
BMRFIXIT
  • 19,053 POSTS
Hi Tim
did you check the TSB
I know they had one on that subject check it out
good luck
Jack
Feb 2, 2008 at 4:47 PM
MASTERTECHTIM
  • 4,750 POSTS
the only bulletin i saw was to make sure the drive gear assembly was set with the proper tool and i did reset it correctly. my next logical guess is the computer but i hate pitching parts.
Feb 2, 2008 at 4:49 PM
BMRFIXIT
  • 19,053 POSTS
[quote:35182713d1="mastertechtim"]the only bulletin i saw was to make sure the drive gear assembly was set with the proper tool and i did reset it correctly. my next logical guess is the computer but i hate pitching parts.[/quote:35182713d1]
i think i saw something in mitchell about that
if you dont have it let me know i will try looking it up and will send it
I hate it when it comes to here and I’m faced with the same question do it throw parts at it
not in my blood I have to make sure something is bad before I change it .
Did you do a wave test
or check cam waves
cylinder balance test
Feb 2, 2008 at 5:12 PM
MASTERTECHTIM
  • 4,750 POSTS
at my shop i have all data, so you might have a bulletin i have not seen in your mitchells on demand. no i did not do a wave test, unfortunately i dont have a scope yet, im using the genesis for now, im trying to convince my partner that the snap on modis is a smart buy, but we have only been in business since july and until now i have not had the need for it. anything you could send would be appreciated. tim
Feb 2, 2008 at 5:16 PM
BMRFIXIT
  • 19,053 POSTS
[quote:d9aae2af9f="mastertechtim"]at my shop i have all data, so you might have a bulletin i have not seen in your mitchells on demand. no i did not do a wave test, unfortunately i dont have a scope yet, im using the genesis for now, im trying to convince my partner that the snap on modis is a smart buy, but we have only been in business since july and until now i have not had the need for it. anything you could send would be appreciated. tim[/quote:d9aae2af9f]
I wish you best of luck with your new shop
I know It take a lot
check your PM
Feb 2, 2008 at 5:59 PM
