99 Deville trouble starting in the mornings...
1999 ALL OTHER MAKES ALL OTHER MODELS
JVJHEN
I have a 99 Deville w/ 95K. The past few mornings I have had a great deal of trouble starting it up. It takes about 15 minutes for it to finally crank up. Funny thing is that once it's started, no problems the rest of the day. It starts on the first try for the entire day. The next morning...same thing. I had one "Check Gas Cap" reading a few days ago but none since. I live in the South so cold weather isn't an issue.
Any clues as to where I should start?
Thanks in advance for your help!!
May 4, 2006 at 5:44 AM
LOSONE
  • 1,616 POSTS
Humm the fuel pump circuit on you car goes through the oil pressure sending unit. How is the oil level and how long since it has been changed?? Let me know
May 4, 2006 at 9:47 AM
JVJHEN
The oil was changed about two monts ago (1500 miles or so). My gauge is reading "oil life left 73%.
May 5, 2006 at 3:32 AM
LOSONE
  • 1,616 POSTS
You really need to have the fuel pressure check when it is cold --- I suspect a bad fuel pump.
May 5, 2006 at 8:40 AM
JVJHEN
Thanks for your input and time.
May 6, 2006 at 7:07 AM
