1998 Ford Windstar Headlights Out
1998 ALL OTHER MAKES ALL OTHER MODELS
JDIPIER2
  • 8 POSTS
I haven't been driving my car because I hurt my ankle and my brother has been driving it once in awhile. So one night he went to go somewhere for me and the headlights didn't go on. The parking lights lit up like usual but not the headlights. The blue light for the high beams lit up when he turned on the headlights. I'm not sure what's wrong. We checked the fuse and it looks fine, what could it be?
Dec 2, 2006 at 1:57 PM
CATCH_15
  • 250 POSTS
Did they go out all-of-the-sudden or did you have problems beforehand such as them only working on the bright setting?
Dec 2, 2006 at 3:09 PM
JDIPIER2
  • 8 POSTS
for awhile the left headlight was dim and if i played around with the wire it would work but it hasn't. the last time we were in it the lights were still working and the one night he went to use my car he turned them on and it didn't work. now the highbeam light goes on when we turn on the headlights. what could it be?
Dec 2, 2006 at 3:21 PM
CATCH_15
  • 250 POSTS
If only the high beams come on, one of the headlights is out. You always want to replace them in pairs though. Replace both bulbs and that should fix the problem.
Dec 2, 2006 at 3:23 PM
JDIPIER2
  • 8 POSTS
the highbeams don't even light up. just light where the controls are lights up when i turn the light switch on. the headlamps aren't working at all
Dec 2, 2006 at 3:47 PM
DOUG V
  • 6 POSTS
l dont know if this will help you but my aerostar had daytime running lights and the module that controled them went goofy.All we did was bypass that module and my lights worked with the manual on/off control on my dash..
Dec 2, 2006 at 3:55 PM
CATCH_15
  • 250 POSTS
Well, if both headlights don't work at all, something has gone bad before the actuall lights. If it worked before, you could try it again. It doesn't sound like the switch on the steering column is bad because the dash indicates high beams.
Dec 2, 2006 at 3:56 PM
JDIPIER2
  • 8 POSTS
hmmm im not sure because i dont have drl lights
Dec 2, 2006 at 4:02 PM
CATCH_15
  • 250 POSTS
I'm not familiar with the particular vehicle, but something is preventive voltage from getting to the headlights.
Dec 2, 2006 at 4:05 PM
JDIPIER2
  • 8 POSTS
[quote:b186bd8cb7="catch_15"]Well, if both headlights don't work at all, something has gone bad before the actuall lights. If it worked before, you could try it again. It doesn't sound like the switch on the steering column is bad because the dash indicates high beams.[/quote:b186bd8cb7]
yea i tried playing with the wire by the light but it's not working :(
JDIPIER2
  • 8 POSTS
[quote:06a4dddedc="catch_15"]I'm not familiar with the particular vehicle, but something is preventive voltage from getting to the headlights.[/quote:06a4dddedc]
i have no idea where to look
Dec 2, 2006 at 4:17 PM
CATCH_15
  • 250 POSTS
Sorry I can't be of more help, I only know so much much about certain vehicles.
Dec 2, 2006 at 4:25 PM
JDIPIER2
  • 8 POSTS
[quote:2fc35819f4="catch_15"]Sorry I can't be of more help, I only know so much much about certain vehicles.[/quote:2fc35819f4]
it's okay thanks for the help i appreciate it!
Dec 2, 2006 at 4:32 PM
JDIPIER2
  • 8 POSTS
I was playing around with the lights yesterday and I got it. It was the right headlight, I pushed in on the part where it connects to the light and bada bing! I guess it was lose? I just wanted to let everyone know I solved the problem!!
Dec 4, 2006 at 10:20 AM
Suggested Repair
Reseat the right headlight connector firmly. The owner found that pushing the loose plug fully onto the right headlight restored the lights. If that does not hold, check the fuse and both bulbs, and look for an upstream power or wiring fault before the lamps.
Conversation Summary
A 1998 Ford Windstar had parking lights and the high-beam indicator, but neither headlight worked. The fuse looked fine, and the left lamp had previously been dim and intermittent when the wire was moved. An expert first suggested replacing both bulbs, then said the column switch was unlikely and that something was blocking voltage to the lamps. The owner later found the right headlight connector was loose; pushing it in restored the headlights.
