98 chev cheyenne 5 L no brake rear sig lights
1998 ALL OTHER MAKES ALL OTHER MODELS
CLIFFW
As stated no brake or rear signal lights. Front signals ok, tail lights ok. Checked fuses beside dash ok. Is there another fuse/breaker panel. Both rear replaced. Any ideas ? Thanks
Mar 6, 2007 at 6:14 AM
CHEVY22
  • 1,375 POSTS
pull the bulbs out again and check for power at the sockets with lights on, if you have no power , a brown wire from both sockets goes to a connector under the truck, locations differ with vin#s just trace the brown wire it powers everything in the rear
Mar 6, 2007 at 11:07 PM
CLIFFW
Thanks. That's what I did. Found there was poor connection at both lights. Pried bulb contacts out a bit to make better contact & it works. What threw me was both going bad at same time. Thanks again. Cliff
Mar 6, 2007 at 11:23 PM
CHEVY22
  • 1,375 POSTS
no problem , you may want to buy new sockets , there are pretty cheap and you wont have thta problem again , but abyway im glad we got it quick
jim
Mar 6, 2007 at 11:39 PM
