97 SLS 4.6L 98k "jerking" problem
RUGBURN
  • 1997 ALL OTHER MAKES ALL OTHER MODELS
First of all, thanks for looking, I have no idea where to look, and after spending over $1200 on tires brakes and an oil change, I don't have a ton of cash for diagnostics. Car was running just fine before the previously mentioned $1200, and this problem popped up suddenly. When it's cold, at a stop (in gear) about every 9 or 10 seconds it seems like there's a "drop", like it loses power for a second? This problem gets less and less pronounced as the car warms up, but then when accelerating or cruising around 12-1800 RPM in 3rd or 4th gear, the car hesitates and jerks. If I give it gas at this point, it backfires, then seems to pick up better. Anything beyond 2000 RPM and it seems to be fine.
EDIT: Forgot to add, I've not recieved any check engine lights (it works at startup) nor does the dash display show anything regarding a problem.
Not sure if these are related, but they might help explain my problem:
I'm not sure, but it seems to want to stay in 3rd gear at 60 MPH, or it's in 4th and the RPM's stay at 2000 for way too long.
Also, the fuel gauge hasn't worked properly for some time, it's correct until there's only about 1/3rd of a tank left, then it will creep back up to 1/2 tank.
I've checked the transmission fluid, all is well, bright pink/red and no burning smell. I suspect it's either a fuel, exhaust or sensor problem. Like I said, it happened SUDDENLY, as far as I can tell, anyways. It is pretty consistant, and does not seem to be getting any worse. Any help or places to start would be greatly appreciated!
Tuesday, January 30th, 2007 AT 12:39 PM
BURN14ME
I have the same car 97 SLS 135k with the same problems I have tried fuel filter, injector cleaner (chemtool B-12) some improvement with first tank. Problem returned I am thinking a possible injector problem. My next step is to drop the fuel tank and clean maybe a dirty tank I also have the same problem with my fuel gage will check when tank is removed. Sometimes it feels like it may be a tranny problem. Hope not!
Wednesday, February 7th, 2007 AT 12:29 PM
TNATCH
I had the same problem, if your getting any virbration it could be your torx convertor. Good luck
Wednesday, April 25th, 2007 AT 10:51 PM
Related Check Engine Light Content
