97 Ram 1500 5.9L Heater Core replacment ????
ALL OTHER MAKES ALL OTHER MODELS
97RAM1500
Hi all, as the title says i own a 97 ram 1500 with the 5.9L 360 with 102,000 miles, I believe I have a heater core issue because earlier this week i began to notice a smell of anti-freeze coming through the vents and the other day i noticed steam coming through the vents once the engine got warm on a slightly cool morning, before I rip apart my entire dash I decided to get advice on what i should look for and any precautions i need to take before i start or if even I am on the right track to fixing this problem. If I am on the right track can anyone assist in what all I have to do to replace it? and what special tools i might need? thanks in advance. Oh and also someone has told me that if I plan to replace the heater core I should also replace the a/c evaporator core, is this true?
May 16, 2007 at 1:57 AM
GWRIGHT74
  • 17 POSTS
good luck. you have to take most of the dash out. tools, no special tools. a/c evaporator core you may want to replace. it's right next to it. it goes out you will be doing this all over again. the only thing is the a/c you need to discharge this. you need a a/c coolent recover system. if you don't you will let all your freeon out.
May 16, 2007 at 2:40 PM
NOMADVALUES
  • 9 POSTS
Did you change your heater-core? If so, did that cure the smell you have of anti-freeze when your heater is on. I have the same truck, but a 1996. I just started to get that smell. Please let me know........
Oct 12, 2008 at 11:01 AM
