96 lumina 3.1 115k acceleration idle problems
1996 ALL OTHER MAKES ALL OTHER MODELS
M1KE378
i have a 96 lumina 3.1 v6 with 115k egr is new and wires and plugs are too. no engine codes appear when it reaches about 2400 rpms it won't accelerate and there is a popping sound like the engine is missing.
May 2, 2006 at 1:31 PM
KINNES
Mike,
I was wondering if you have ever encountered a problem with your breaks? We just bought the car, and had it checked over/safety two days ago. It all worked fine. Now, the brake lights won't come on, but the window brake light does? We have changed the bulb, checked the fuses, and now are stumped. If it were a wire problem wouldn't the back break light not work as well?
Just wondering if you knew anything.. any help would be great
May 4, 2006 at 1:20 PM
IMPORTBASHER89
  • 29 POSTS
sounds like veh. is lean maybe need to check fuel pressure and vol.
May 5, 2006 at 10:45 AM
IMPORTBASHER89
  • 29 POSTS
brake lights don't work but third brake light does?
this is cause by a bad connection in the turn sig. switch
May 5, 2006 at 10:49 AM
