96 Grand am door locks
1996 ALL OTHER MAKES ALL OTHER MODELS
BIGGMANN
The door locks on my 96 grand am 3.1 have stopped working, they lock when it is put into drive and unlock only when the car is shut off, the door lock switchs dont work at all. I have checked the fuses and are fine except there is no power going to the one door lock fuse. I dont know if this has anything else to do with it but my air bag light, seat belt light, and coolent light stay on also my front power windows slowly roll down about 5 inches then will not roll up but a tiny bit at a time and i have to let them "rest" then try again to only move the littlest bit. Again I dont know if these are related to the door lock issue or just more problems. I have tried everything I know to fix the locks so if anyone knows anything to try please let me know.
Jan 10, 2006 at 12:12 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Verify the reported fuse supply with the matching wiring diagram and test the affected circuits under load. Have the airbag and coolant warnings assessed separately rather than assuming one shared cause.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for testing loaded electrical circuits. Use the actual vehicle wiring and specifications.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
check the main power center under the hood. Sound like the window motors are weak
Jan 11, 2006 at 7:31 AM
BIGGMANN
where is the main power center located? Is that where all the fuses are located under the hood and if so what is it I am looking for?
Jan 11, 2006 at 10:25 AM
Discussion summary
A 1996 Grand Am had inoperative door-lock switches although automatic locking still worked. The owner reported no power at one lock fuse, slow window movement and several illuminated warning lamps.
Reported outcome: No measured circuit fault or repair was reported.
Weak window motors and a main power-center problem were suggestions. The discussion did not establish that the locks, windows and warning lamps shared a fault.
Read the original discussion
