95 elantra-lights won't come on
1995 ALL OTHER MAKES ALL OTHER MODELS
MDEMINT
Our 95 Elantra will start, but the lights (break lights, head lights, etc) will not usually come on. Once in a while, we will get lucky and they will, but most of the time not. We have tried new battery. Any suggestions?
May 3, 2007 at 5:46 AM
BRUCE HUNT
  • 3,754 POSTS
Give the year and that it is now 12 years old, there is a possibility that corrosion of connections is a problem. Especially for grounding. Check the fuses, pull them and reseat them. The check and possibly replace the relays for the headlights. I doubt the battery is at fault or the alternator but the grounding points of the car and there can be several may be corroded and need to be removed, cleaned and reseated.
May 3, 2007 at 5:53 AM
