My 94 Explorer XL 2wd, w/ 65000 miles on it will not start. When I turn the key, the solenoid and the starter make loud clicking noises but the engine does not crank.
I tried charging the battery and then I pulled both the solenoid and starter and had them checked at a local high school shop and both were fine (not sure if a pro could check better).
I had a problem with mice chewing on wires before but the wires between the solenoid and starter are intact.
What else can I check myself and at what point should I take it to a pro? I've read some horror stories about a pro pulling and replacing all sorts of things without fixing the problem (starter/flywheel/etc) and don't want to have to pay that much. Thanks for the help!
Apr 30, 2006 at 4:54 AM
