94 Grand Caravan, 3.8L, 231K miles
My brake lights were stuck on one night, so I pulled the fuse for the brake lights so the battery would not go down before I had a chance to trouble shoot. In the process of pulling the fuse, I created a short on the fuse panel. The next day, I checked fuses in that area and all are good. The brake light fuse had continuity, so I put it back and the brake lights work fine-not sticking. There was a smell of burnt insulation.
I can't find any fuses that do not work, but these functions do not work: remote control, remote door locks, remote mirror control, ammeter gauge, ceiling lights, radio. The tailgate release button only works now when the key is on, whereas it normally works either way.
I can't see any burnt wires or fuses. The Owner's Manual speaks of a "circuit breaker" behind the console somewhere, but does not give specifics. Could that be the problem? If so, exactly where is it and is it something I can fix or replace?
Thank you for your guidance.
Feb 25, 2007 at 7:44 PM
